Conference papers
Simultaneous Information and Energy Transmission with Finite Constellations
Abstract : In this paper, the fundamental limits on the rates at which information and energy can be simultaneously transmitted over an additive white Gaussian noise channel are studied under the following assumptions: (a) the channel is memoryless; (b) the number of channel input symbols (constellation size) and block length are finite; and (c) the decoding error probability (DEP) and the energy outage probability (EOP) are bounded away from zero. In particular, it is shown that the limits on the maximum information and energy transmission rates; and the minimum DEP and EOP, are essentially set by the type induced by the code used to perform the transmission. That is, the empirical frequency with which each channel input symbol appears in the codewords. Using this observation, guidelines for optimal constellation design for simultaneous energy and information transmission are presented.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03339165
Contributor : Sadaf ul Zuhra Connect in order to contact the contributor
Submitted on : Thursday, September 9, 2021 - 12:59:58 PM
Last modification on : Saturday, June 25, 2022 - 11:52:01 PM
Long-term archiving on: : Saturday, December 11, 2021 - 7:22:33 AM
File
SIET with finite constellation...
Identifiers
Citation
Sadaf Ul Zuhra, Samir M. Perlaza, Eitan Altman. Simultaneous Information and Energy Transmission with Finite Constellations. ITW 2021 - IEEE Information Theory Workshop, Oct 2021, Kanazawa, Japan. pp.1-6, ⟨10.1109/ITW48936.2021.9611494⟩. ⟨hal-03339165⟩
Share
Metrics
Record views
76
Files downloads
151
