Realizing semicomputable simplices by computable dynamical systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2022
We study the computability of the set of invariant measures of a computable dynamical system. It is known to be semicomputable but not computable in general, and we investigate which semicomputable simplices can be realized in this way. We prove that every semicomputable finite-dimensional simplex can be realized, and that every semicomputable finite-dimensional convex set is the projection of the set of invariant measures of a computable dynamical system. In particular, there exists a computable system having exactly two ergodic measures, none of which is computable. Moreover, all the dynamical systems that we build are minimal Cantor systems.
article.pdf (341.13 Ko) Télécharger le fichier
hal-03339422 , version 1 (09-09-2021)
Paternité
Daniel Coronel, Alexander Frank, Mathieu Hoyrup, Cristóbal Rojas. Realizing semicomputable simplices by computable dynamical systems. Theoretical Computer Science, 2022, 933, pp.43-54. ⟨10.1016/j.tcs.2022.09.001⟩. ⟨hal-03339422⟩
77 Consultations
86 Téléchargements
