Splittable Routing Games in Ring Topology with Losses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider a splittable atomic game with lossy links on a ring in which the cost that each player i minimizes is their own loss rate of packets. The costs are therefore non-additive (unlike costs based on delays or tolls) and moreover, there is no flow conservation (total flow entering a link is greater than the flow leaving it). We derive a closed-form for the equilibrium, which allows us to obtain insight on the structure of the equilibrium. We also derive the globally optimal solution and obtain conditions for the equilibrium to coincide with the globally optimal solution.
p4.pdf (812.64 Ko) Télécharger le fichier
hal-03340020 , version 1 (09-09-2021)
Sami Dallali, Clara Fontaine, Eitan Altman. Splittable Routing Games in Ring Topology with Losses. ASMTA 2021 - 26th International Conference on Analytical & Stochastic Modelling Techniques & Applications, Dec 2021, Virtual, Japan. ⟨10.1007/978-3-030-91825-5_18⟩. ⟨hal-03340020⟩
65 Consultations
40 Téléchargements
