Fair Refinement for Asynchronous Session Types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Session types are widely used as abstractions of asynchronous message passing systems. Refinement for such abstractions is crucial as it allows improvements of a given component without compromising its compatibility with the rest of the system. In the context of session types, the most general notion of refinement is the asynchronous session subtyping, which allows to anticipate message emissions but only under certain conditions. In particular, asynchronous session subtyping rules out candidates subtypes that occur naturally in communication protocols where, e.g., two parties simultaneously send each other a finite but unspecified amount of messages before removing them from their respective buffers. To address this shortcoming, we study fair compliance over asynchronous session types and fair refinement as the relation that preserves it. This allows us to propose a novel variant of session subtyping that leverages the notion of controllability from service contract theory and that is a sound characterisation of fair refinement. In addition, we show that both fair refinement and our novel subtyping are undecidable. We also present a sound algorithm, and its implementation, which deals with examples that feature potentially unbounded buffering.
Bravetti2021_Chapter_FairRefinementForAsynchronousS.pdf (492.74 Ko) Télécharger le fichier
hal-03340696 , version 1 (10-09-2021)
Mario Bravetti, Julien Lange, Gianluigi Zavattaro. Fair Refinement for Asynchronous Session Types. FOSSACS 2021 - 24th International Conference on Foundations of Software Science and Computation Structures, Mar 2021, Luxembourgh, Luxembourg. ⟨10.1007/978-3-030-71995-1⟩. ⟨hal-03340696⟩
16 Consultations
93 Téléchargements
