The supersingular isogeny path and endomorphism ring problems are equivalent - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We prove that the path-finding problem in isogeny graphs and the endomorphism ring problem for supersingular elliptic curves are equivalent under reductions of polynomial expected time, assuming the generalised Riemann hypothesis. The presumed hardness of these problems is foundational for isogeny-based cryptography. As an essential tool, we develop a rigorous algorithm for the quaternion analog of the path-finding problem, building upon the heuristic method of Kohel, Lauter, Petit and Tignol. This problem, and its (previously heuristic) resolution, are both a powerful cryptanalytic tool and a building-block for cryptosystems.
paper.pdf (498.16 Ko) Télécharger le fichier
hal-03340899 , version 1 (10-09-2021)
  • HAL Id : hal-03340899 , version 1
Benjamin Wesolowski. The supersingular isogeny path and endomorphism ring problems are equivalent. FOCS 2021 - 62nd Annual IEEE Symposium on Foundations of Computer Science, Feb 2022, Denver, Colorado, United States. ⟨hal-03340899⟩
125 Consultations
237 Téléchargements
