Optimal transportation, modelling and numerical simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Acta Numerica Année : 2021
We present an overviewof the basic theory, modern optimal transportation extensions and recent algorithmic advances. Selected modelling and numerical applications illustrate the impact of optimal transportation in numerical analysis.
benamou-HAL.pdf (128.27 Mo) Télécharger le fichier
hal-03344549 , version 1 (15-09-2021)
Jean-David Benamou. Optimal transportation, modelling and numerical simulation. Acta Numerica, 2021, 30, pp.249-325. ⟨10.1017/S0962492921000040⟩. ⟨hal-03344549⟩
341 Consultations
58 Téléchargements
