Dantzig–Wolfe decomposition for the design of filterless optical networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Optical Communications and Networking Année : 2021
Filterless optical networks use passive splitters and combiners with coherent optics, providing wavelength selection in the digital domain, while forming a passive fiber-tree topology between nodes. In this study, we investigate the optimal design of filterless optical networks while minimizing the number of required wavelengths. We propose a Dantzig-Wolfe decomposition model in which each subproblem aims to generate a potential filterless optical subnetwork, with a directed tree topology. The master problem then selects the best combination of subnetworks. Numerical experiments demonstrate significant performance improvement over previous work, reducing previous computational results by a factor of 2 to 10 depending on the size of the data instances.
JOCN_2021_hal_2col.pdf (708.86 Ko) Télécharger le fichier
hal-03345749 , version 1 (15-09-2021)
Brigitte Jaumard, Yan Wang, David Coudert. Dantzig–Wolfe decomposition for the design of filterless optical networks. Journal of Optical Communications and Networking, 2021, 13 (12), pp.10. ⟨10.1364/JOCN.424415⟩. ⟨hal-03345749⟩
33 Consultations
180 Téléchargements
