Consensus-Free Ledgers When Operations of Distinct Processes are Commutative - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Considering asynchronous message-passing systems in which any number of processes may crash, this article addresses the construction of ledger objects where (i) the append operations issued from distinct processes commute, while (ii) the append operations issued from the same process do not. In a very interesting way, it appears that the implementation of such ledgers does not need consensus, which makes them both attractive and efficient. Their underlying formalization rests on Mazurkiewicz's traces.
Consensus-free-ledger-commute-operations-V11.pdf (284.67 Ko) Télécharger le fichier
hal-03346756 , version 1 (16-09-2021)
Davide Frey, Lucie Guillou, Michel Raynal, François Taïani. Consensus-Free Ledgers When Operations of Distinct Processes are Commutative. PaCT 2021 - 16th International Conference on Parallel Computing Technologies, Sep 2021, Kaliningrad, Russia. pp.359-370, ⟨10.1007/978-3-030-86359-3_27⟩. ⟨hal-03346756⟩
48 Consultations
177 Téléchargements
