Tracking of blood vessels motion from 4D-flow MRI data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Cardiovascular Engineering and Technology Année : 2023
This paper presents a novel approach to track objects from 4D Flow MRI data. A salient feature of the proposed method is that it fully exploits the geometrical and dynamical nature of the information provided by this imaging modality. The underlying idea consists in formulating the tracking problem as a data assimilation problem, in which both position and velocity observations are extracted from the 4D Flow MRI data series. Optimal estate estimation is then performed in a sequential fashion via Kalman filtering. The capabilities of the method are extensively assessed in a numerical study involving synthetic and clinical data.
paper_pub.pdf (12.37 Mo) Télécharger le fichier
hal-03349442 , version 1 (20-09-2021)
hal-03349442 , version 2 (25-09-2022)
hal-03349442 , version 3 (05-09-2023)
Paternité
Mocia Agbalessi, Alain Lalande, Olivier Bouchot, Toshiyuki Hayase, Jean-Joseph Christophe, et al.. Tracking of blood vessels motion from 4D-flow MRI data. Cardiovascular Engineering and Technology, 2023, 14, pp.577-604. ⟨10.1007/s13239-023-00677-z⟩. ⟨hal-03349442v3⟩
281 Consultations
133 Téléchargements
