Monolingual and cross-lingual intent detection without training data in target languages
Due to recent DNN advancements, many NLP problems can be effectively solved using transformer-based models and supervised data. Unfortunately, such data is not available in some languages. This research is based on assumptions that (1) training data can be obtained by the
machine translating it from another language; (2) there are cross-lingual solutions that work without the training data in the target language. Consequently, in this research, we use the English dataset and solve the intent detection problem for five target languages (German, French, Lithuanian, Latvian, and Portuguese). When seeking the most accurate solutions, we investigate BERT-based word and sentence transformers together with eager learning classifiers (CNN, BERT fine-tuning, FFNN) and lazy learning approach (Cosine similarity as the memory-based method). We offer and evaluate several strategies to overcome the data scarcity problem with machine translation, crosslingual models, and a combination of the previous two. The experimental investigation revealed the robustness of sentence transformers under various cross-lingual conditions. The accuracy equal to ~0.842 is achieved with the English dataset with completely monolingual models is considered our
top-line. However, cross-lingual approaches demonstrate similar accuracy levels reaching ~0.831, ~0.829, ~0.853, ~0.831, and ~0.813 on German, French, Lithuanian, Latvian, and Portuguese languages.
