Inner-ear Augmented Metal Artifact Reduction with Simulation-based 3D Generative Adversarial Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computerized Medical Imaging and Graphics Année : 2021
Metal Artifacts creates often difficulties for a high-quality visual assessment of post-operative imaging in computed tomography (CT). A vast body of methods have been proposed to tackle this issue, but these methods were designed for regular CT scans and their performance is usually insufficient when imaging tiny implants. In the context of post-operative high-resolution CT imaging, we propose a 3D metal artifact reduction algorithm based on a generative adversarial neural network. It is based on the simulation of physically realistic CT metal artifacts created by cochlea implant electrodes on preoperative images. The generated images serve to train 3D generative adversarial networks for artifacts reduction. The proposed approach was assessed qualitatively and quantitatively on clinical conventional and cone-beam CT of cochlear implant postoperative images. These experiments show that the proposed method outperforms other general metal artifact reduction approaches.
Margan_Clean_Latex (1).pdf (18.76 Mo) Télécharger le fichier
hal-03351225 , version 1 (22-09-2021)
Zihao Wang, Clair Vandersteen, Thomas Demarcy, Dan Gnansia, Charles Raffaelli, et al.. Inner-ear Augmented Metal Artifact Reduction with Simulation-based 3D Generative Adversarial Networks. Computerized Medical Imaging and Graphics, In press, 93, pp.101990. ⟨10.1016/j.compmedimag.2021.101990⟩. ⟨hal-03351225⟩
75 Consultations
67 Téléchargements
