Total variation distance between a jump-equation and its Gaussian approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastics and Partial Differential Equations: Analysis and Computations Année : 2022
Vlad Bally
  • Fonction : Auteur
  • PersonId : 950772
Yifeng Qin
  • Fonction : Auteur
  • PersonId : 753089
  • IdHAL : yifeng-qin
We deal with stochastic differential equations with jumps. In order to obtain an accurate approximation scheme, it is usual to replace the "small jumps" by a Brownian motion. In this paper, we prove that for every fixed time $t$, the approximate random variable $X^\varepsilon_t$ converges to the original random variable $X_t$ in total variation distance and we estimate the error. We also give an estimate of the distance between the densities of the laws of the two random variables. These are done by using some integration by parts techniques in Malliavin calculus.
Totalvariation (1).pdf (518.36 Ko) Télécharger le fichier
Totalvariation.pdf (518.36 Ko) Télécharger le fichier
structure.tex (6.42 Ko) Télécharger le fichier
hal-03351643 , version 1 (22-09-2021)
hal-03351643 , version 2 (23-03-2022)
hal-03351643 , version 3 (25-10-2022)
Vlad Bally, Yifeng Qin. Total variation distance between a jump-equation and its Gaussian approximation. Stochastics and Partial Differential Equations: Analysis and Computations, 2022, ⟨10.1007/s40072-022-00270-w⟩. ⟨hal-03351643v3⟩
171 Consultations
119 Téléchargements
