Conference papers
DataTime: a Framework to smoothly Integrate Past, Present and Future into Models
Gauthier Lyan 1 Jean-Marc Jézéquel 2 David Gross-Amblard 3 Benoit Combemale 2
2 DiverSe - Diversity-centric Software Engineering
Inria Rennes – Bretagne Atlantique , IRISA-D4 - LANGAGE ET GÉNIE LOGICIEL
Abstract : Models at runtime have been initially investigated for adaptive systems. Models are used as a reflective layer of the current state of the system to support the implementation of a feedback loop. More recently, models at runtime have also been identified as key for supporting the development of fullfledged digital twins. However, this use of models at runtime raises new challenges, such as the ability to seamlessly interact with the past, present and future states of the system. In this paper, we propose a framework called DataTime to implement models at runtime which capture the state of the system according to the dimensions of both time and space, here modeled as a directed graph where both nodes and edges bear local states (ie. values of properties of interest). DataTime provides a unifying interface to query the past, present and future (predicted) states of the system. This unifying interface provides i) an optimized structure of the time series that capture the past states of the system, possibly evolving over time, ii) the ability to get the last available value provided by the system’s sensors, and iii) a continuous micro-learning over graph edges of a predictive model to make it possible to query future states, either locally or more globally, thanks to a composition law. The framework has been developed and evaluated in the context of the Intelligent Public Transportation Systems of the city of Rennes (France). This experimentation has demonstrated how DataTime can deprecate the use of heterogeneous tools for managing data from the past, the present and the future, and facilitate the development of digital twins.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03355162
Contributor : Benoit Combemale Connect in order to contact the contributor
Submitted on : Monday, September 27, 2021 - 11:01:18 AM
Last modification on : Friday, August 5, 2022 - 2:54:52 PM
Long-term archiving on: : Tuesday, December 28, 2021 - 6:20:26 PM
File
DataTime__a_framework_to_smoot...
Identifiers
  • HAL Id : hal-03355162, version 1
Citation
Gauthier Lyan, Jean-Marc Jézéquel, David Gross-Amblard, Benoit Combemale. DataTime: a Framework to smoothly Integrate Past, Present and Future into Models. MODELS 2021 - ACM/IEEE 24th International Conference on Model Driven Engineering Languages and Systems, Oct 2021, Fukuoka, Japan. pp.1-11. ⟨hal-03355162⟩
Share
Metrics
Record views
104
Files downloads
162
