Isomorphisms are back! - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sometimes, we need a function so deeply that we have to go out and search for it. How do we find it ? Sometimes, we have clues: a function which manipulates list is probably in the Listmodule. . . but not always! Sometimes, all we have is its functionality: doing the sum of a list of integers. Unfortunately, search by functionality is difficult. Rittri [1] proposed an approximation: use the type of the function as a key to search through libraries: in our case, int list->int. To avoid stumbling over details such as the order of arguments, he proposed to use matching modulo type isomorphism – a notion broader than syntactic equality. Unfortunately, algorithms for unification modulo type isomorphisms are extremely costly. Doing an exhaustive search over the whole ML ecosystem was possible at the time (with a standard library of 294 functions), but is certainly not possible anymore for the OCaml ecosystem, with 3259 opam packages, each containing several hundreds or thousands of functions.
mlworkshop.pdf (114.81 Ko) Télécharger le fichier
hal-03355381 , version 1 (27-09-2021)
  • HAL Id : hal-03355381 , version 1
Clément Allain, Gabriel Radanne, Laure Gonnord. Isomorphisms are back!: Smart indexing for function retrieval by unification modulo type isomorphisms. ML 2021 - ML Workshop, Aug 2021, Virtual, France. pp.1-3. ⟨hal-03355381⟩
191 Consultations
96 Téléchargements
