New interface
Journal articles
A Novel Niederreiter-like cryptosystem based on the ( u | u + υ )-construction codes
Abstract : In this paper, we present a new variant of the Niederreiter Public Key Encryption (PKE) scheme which is resistant against recent attacks. The security is based on the hardness of the Rank Syndrome Decoding (RSD) problem and it presents a ( u | u + υ )-construction code using two different types of codes: Ideal Low Rank Parity Check (ILRPC) codes and λ -Gabidulin codes. The proposed encryption scheme benefits are a larger minimum distance, a new efficient decoding algorithm and a smaller ciphertext and public key size compared to the Loidreau’s variants and to its IND-CCA secure version.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-03355933
Contributor : Pierre-Louis Cayrel Connect in order to contact the contributor
Submitted on : Monday, September 27, 2021 - 3:56:35 PM
Last modification on : Friday, August 5, 2022 - 2:54:44 PM
Links full text
Identifiers
Collections
Citation
Roumaissa Mahdjoubi, Pierre Louis Cayrel, Sedat Akleylek, Guenda Kenza. A Novel Niederreiter-like cryptosystem based on the ( u | u + υ )-construction codes. RAIRO - Theoretical Informatics and Applications (RAIRO: ITA), 2021, 55, pp.10. ⟨10.1051/ita/2021010⟩. ⟨hal-03355933⟩
Share
Metrics
Record views
31
