Concurrent Programming in Pharo
This book describes the low-level abstractions available in Pharo for concur-rent programming. It explains pedagogically different aspects. Now, if youhappen to create many green threads (called Process in Pharo) we suggestthat you have a look at TaskIt. TaskIt is an extensible library to manage con-current processing at a higher-level of abstractions. You should definitivelyhave a look at it.
Langage de programmation [cs.PL]
