Journal articles
Comparing the performance of rigid, moldable and grid-shaped applications on failure-prone HPC platforms
Abstract : This paper compares the performance of different approaches to tolerate failures for applications executing on large-scale failure-prone platforms. We study (i) Rigid applications, which use a constant number of processors throughout execution; (ii) Moldable applications, which can use a different number of processors after each restart following a fail-stop error; and (iii) GridShaped applications, which are moldable applications restricted to use rectangular processo grids (such as many dense linear algebra kernels). We start with checkpoint/ restart, the de-facto standard approach. For each application type, we compute the optimal number of failures (i.e. that maximizes the yield of the application) to tolerate before relinquishing the current allocation and waiting until a new resource can be allocated, and we determine the optimal yield that can be achieved. For GridShaped applications, we also investigate Application Based Fault Tolerance (ABFT) techniques and perform the same analysis, computing the optimal number of failures to tolerate and the associated yield. We instantiate our performance model with realistic applicative scenarios and make it publicly available for further usage. We show that using spare nodes grants a much better yield than currently used strategies that restart after each failure. Moreover, the yield is similar for Rigid, Moldable and GridShaped applications, while the optimal number of failures to tolerate is very high, even for a short wait time in between allocations. Finally, Moldable applications have the advantage to restart less frequently than Rigid applications.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-03360189
Contributor : Accord Elsevier CCSD Connect in order to contact the contributor
Submitted on : Friday, October 22, 2021 - 6:38:02 PM
Last modification on : Friday, July 8, 2022 - 10:07:23 AM
Long-term archiving on: : Monday, January 24, 2022 - 5:01:33 PM
File
S0167819118302230.pdf
Distributed under a Creative Commons Attribution - NonCommercial 4.0 International License
Identifiers
Collections
Citation
Valentin Le Fèvre, Thomas Herault, Yves Robert, Aurelien Bouteiller, Atsushi Hori, et al.. Comparing the performance of rigid, moldable and grid-shaped applications on failure-prone HPC platforms. Parallel Computing, Elsevier, 2019, 85, pp.1-12. ⟨10.1016/j.parco.2019.02.002⟩. ⟨hal-03360189⟩
Share
Metrics
Record views
18
Files downloads
34
