Disentangling Syntax and Semantics in the Brain with Deep Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The activations of language transformers like GPT-2 have been shown to linearly map onto brain activity during speech comprehension. However, the nature of these activations remains largely unknown and presumably conflate distinct linguistic classes. Here, we propose a taxonomy to factorize the high-dimensional activations of language models into four combinatorial classes: lexical, compositional, syntactic, and semantic representations. We then introduce a statistical method to decompose, through the lens of GPT-2's activations, the brain activity of 345 subjects recorded with functional magnetic resonance imaging (fMRI) during the listening of 4.6 hours of narrated text. The results highlight two findings. First, compositional representations recruit a more widespread cortical network than lexical ones, and encompass the bilateral temporal, parietal and prefrontal cortices. Second, contrary to previous claims, syntax and semantics are not associated with separated modules, but, instead, appear to share a common and distributed neural substrate. Overall, this study introduces a versatile framework to isolate, in the brain activity, the distributed representations of linguistic constructs.
Narratives_Syntax_semantics.pdf (3.87 Mo) Télécharger le fichier
hal-03361421 , version 1 (01-10-2021)
  • HAL Id : hal-03361421 , version 1
Charlotte Caucheteux, Alexandre Gramfort, Jean-Remi King. Disentangling Syntax and Semantics in the Brain with Deep Networks. ICML 2021 - 38th International Conference on Machine Learning, Jul 2021, Online conference, France. ⟨hal-03361421⟩
119 Consultations
122 Téléchargements
