New interface
Conference papers
AGINFRA PLUS: Running Crop Simulations on the D4Science Distributed e-Infrastructure
Abstract : Virtual Research Environments (VREs) bridge the gap between the compute and storage infrastructure becoming available as the ‘cloud’, and the needs of researchers for tools supporting open science and analytics on ever larger datasets. In the AGINFRA PLUS project such a VRE, based on the D4Science platform, was examined to improve and test its capabilities for running large numbers of crop simulations at field level, based on the WOFOST-WISS model and Dutch input datasets from the AgroDataCube. Using the gCube DataMiner component of the VRE, and based on the Web Processing Service standard, a system has been implemented that can run such workloads successfully on an available cluster, and with good performance, providing summarized results to agronomists for further analysis. The methods used and the resulting implementation are briefly described in this paper. Overall the approach seems viable and opening the door to many follow-up implementation opportunities and further research. Some of them are indicated in more detail in the conclusions.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03361878
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, October 1, 2021 - 3:40:04 PM
Last modification on : Wednesday, November 3, 2021 - 7:05:50 AM
Long-term archiving on: : Sunday, January 2, 2022 - 7:26:01 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2023-01-01
Please log in to resquest access to the document
Identifiers
Citation
M. Knapen, Rob M. Lokers, Leonardo Candela, Sander Janssen. AGINFRA PLUS: Running Crop Simulations on the D4Science Distributed e-Infrastructure. 13th International Symposium on Environmental Software Systems (ISESS), Feb 2020, Wageningen, Netherlands. pp.81-89, ⟨10.1007/978-3-030-39815-6_8⟩. ⟨hal-03361878⟩
Share
Metrics
Record views
9
