WISS a Java Continuous Simulation Framework for Agro-Ecological Modelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
D. Kraalingen
  • Fonction : Auteur
  • PersonId : 1111995
M. Knapen
  • Fonction : Auteur
  • PersonId : 1111966
A. De Wit
  • Fonction : Auteur
  • PersonId : 1111996
A simulation framework is presented (WISS, Wageningen Integrated Systems Simulator) which targets the agro-ecological modelling domain. Especially simulation for a large number of locations, such as in detailed regional and global simulation studies. The framework strengths are in modularization, control, speed, robustness and computational protection (multiple system checks during simulation). The WOFOST model is currently implemented in WISS, through which it is used in a number of Wageningen University and Research projects. WISS is written in Java and the framework code is freely available.
493342_1_En_23_Chapter.pdf (233.16 Ko) Télécharger le fichier
hal-03361894 , version 1 (01-10-2021)
Paternité
D. Kraalingen, M. Knapen, A. De Wit, H. L. Boogaard. WISS a Java Continuous Simulation Framework for Agro-Ecological Modelling. 13th International Symposium on Environmental Software Systems (ISESS), Feb 2020, Wageningen, Netherlands. pp.242-248, ⟨10.1007/978-3-030-39815-6_23⟩. ⟨hal-03361894⟩
38 Consultations
26 Téléchargements
