New interface
Reports (Research report)
Disambiguate the storage class of some compound literals: change request for C23
Jens Gustedt 1 Martin Uecker 2
1 CAMUS - Compilation pour les Architectures MUlti-coeurS
Inria Nancy - Grand Est, ICube - Laboratoire des sciences de l'ingénieur, de l'informatique et de l'imagerie
Abstract : We noticed that there is a need for clarification about the storage class of compound literals that are evaluated in the type expressions of function parameters. It turned out that clang has them as static storage duration while gcc has them as automatic. We asked WG14 to clarify this situation and consensus (13-0-8) has been reached that it should be specified as automatic. This paper implements that change.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-03363683
Contributor : Jens Gustedt Connect in order to contact the contributor
Submitted on : Monday, October 4, 2021 - 10:31:51 AM
Last modification on : Saturday, November 5, 2022 - 3:58:20 AM
Long-term archiving on: : Wednesday, January 5, 2022 - 6:17:28 PM
File
n2819.pdf
Identifiers
  • HAL Id : hal-03363683, version 1
Citation
Jens Gustedt, Martin Uecker. Disambiguate the storage class of some compound literals: change request for C23. [Research Report] 2819, ISO JCT1/SC22/WG14. 2021, pp.2. ⟨hal-03363683⟩
Share
Metrics
Record views
22
Files downloads
30
