Dynamic Repair of Mission-Critical Applications with Runtime Snap-Ins - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
J. Peter Brady
  • Fonction : Auteur
  • PersonId : 1112206
This chapter proposes a solution that provides reliable, non-disruptive updates to critical systems using a novel design pattern called a “snap-in,” which is able to install replacement routines embedded in shared libraries during system execution. Most system updates are performed in a static or maintenance state. However, dynamically updating software reduces the time required for adding functionality and applying security upgrades. The proposed snap-in solution improves on previous work by adopting the novel approach of using the target’s application binary interface to first load shared libraries that contain replacement routines into a running application, supplanting the original routines with replacement routines without having to modify the existing code. An automated toolkit is provided for scanning application binaries and determining where the replacement routines are to be added.
491841_1_En_12_Chapter.pdf (599.19 Ko) Télécharger le fichier
hal-03364571 , version 1 (04-10-2021)
Paternité
J. Peter Brady, Sergey Bratus, Sean Smith. Dynamic Repair of Mission-Critical Applications with Runtime Snap-Ins. 13th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2019, Arlington, VA, United States. pp.235-252, ⟨10.1007/978-3-030-34647-8_12⟩. ⟨hal-03364571⟩
32 Consultations
19 Téléchargements
