Spurious Valleys, NP-hardness, and Tractability of Sparse Matrix Factorization With Fixed Support - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
The problem of approximating a dense matrix by a product of sparse factors is a fundamental problem for many signal processing and machine learning tasks. It can be decomposed into two subproblems: finding the position of the non-zero coefficients in the sparse factors, and determining their values. While the first step is usually seen as the most challenging one due to its combinatorial nature, this paper focuses on the second step, referred to as sparse matrix approximation with fixed support. First, we show its NP-hardness, while also presenting a nontrivial family of supports making the problem practically tractable with a dedicated algorithm. Then, we investigate the landscape of its natural optimization formulation, proving the absence of spurious local valleys and spurious local minima, whose presence could prevent local optimization methods to achieve global optimality. The advantages of the proposed algorithm over state-of-the-art first-order optimization methods are discussed.
main.pdf (1.37 Mo) Télécharger le fichier
hal-03364668 , version 1 (06-10-2021)
hal-03364668 , version 2 (08-10-2021)
hal-03364668 , version 3 (29-11-2021)
hal-03364668 , version 4 (11-07-2022)
hal-03364668 , version 5 (16-11-2022)
Quoc-Tung Le, Elisa Riccietti, Rémi Gribonval. Spurious Valleys, NP-hardness, and Tractability of Sparse Matrix Factorization With Fixed Support. 2021. ⟨hal-03364668v4⟩
478 Consultations
364 Téléchargements
