On Homogeneous Approximations, Stability and Robustness of Infinite Dimensional Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
The paper generalizes the concept of homogeneous approximations to a class of unbounded operators satisfying certain regularity assumptions. Stability and robustness of locally homogeneous abstract control systems are studied. The viscous Burgers equation and its nonlinear modifications are considered as illustrative examples.
Automatique
main.pdf (432.6 Ko) Télécharger le fichier
hal-03366756 , version 1 (05-10-2021)
hal-03366756 , version 2 (08-10-2021)
  • HAL Id : hal-03366756 , version 2
Andrey Polyakov. On Homogeneous Approximations, Stability and Robustness of Infinite Dimensional Systems. 2021. ⟨hal-03366756v2⟩
84 Consultations
151 Téléchargements
