Identifying homogeneous subgroups of patients and important features: a topological machine learning approach
Background
This paper exploits recent developments in topological data analysis to present a pipeline for clustering based on Mapper, an algorithm that reduces complex data into a one-dimensional graph.
Results
We present a pipeline to identify and summarise clusters based on statistically significant topological features from a point cloud using Mapper.
Conclusions
Key strengths of this pipeline include the integration of prior knowledge to inform the clustering process and the selection of optimal clusters; the use of the bootstrap to restrict the search to robust topological features; the use of machine learning to inspect clusters; and the ability to incorporate mixed data types. Our pipeline can be downloaded under the GNU GPLv3 license at https://github.com/kcl-bhi/mapper-pipeline.
