Data-Driven Sparse Partial Least Squares - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Statistical Analysis and Data Mining Année : 2022
In the supervised high dimensional settings with a large number of variables and a low number of individuals, variable selection allows a simpler interpretation and more reliable predictions. That subspace selection is often managed with supervised tools when the real question is motivated by variable prediction. We propose a Partial Least Square (PLS) based method, called data-driven sparse PLS (ddsPLS), allowing variable selection both in the covariate and the response parts using a single hyper-parameter per component. The subspace estimation is also performed by tuning a number of underlying parameters. The ddsPLS method is compared to existing methods such as classical PLS and two well established sparse PLS methods through numerical simulations. The observed results are promising both in terms of variable selection and prediction performance. This methodology is based on new prediction quality descriptors associated with the classical R 2 and Q 2 and uses bootstrap sampling to tune parameters and select an optimal regression model.
ddsPLS_tout_seul_no_bib_Pour_HAL_Inria.pdf (1.03 Mo) Télécharger le fichier
hal-03368956 , version 1 (07-10-2021)
Hadrien Lorenzo, Olivier Cloarec, Rodolphe Thiébaut, Jérôme Saracco. Data-Driven Sparse Partial Least Squares. Statistical Analysis and Data Mining, 2022, 15 (2), pp.264-282. ⟨10.1002/sam.11558⟩. ⟨hal-03368956⟩
97 Consultations
320 Téléchargements
