The Effect of Increased Body Motion in Virtual Reality on a Placement-Retrieval Task - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Previous work has shown that increased effort and use of one's body can improve memory. When positioning windows inside a virtual reality, does the use of a larger volume, and using one's legs to move around, improve the ability to later find the windows? The results of our experiment indicate there can be a modest benefit for spatial memory and retrieval time, but at the cost of increased time spent initially positioning the windows.
Body_Motion_and_Spatial_Memory_in_VR (1).pdf (2.16 Mo) Télécharger le fichier
hal-03368978 , version 1 (07-10-2021)
Thibault Friedrich, Arnaud Prouzeau, Michael J Mcguffin. The Effect of Increased Body Motion in Virtual Reality on a Placement-Retrieval Task. VRST 2021 - 27th ACM Symposium on Virtual Reality Software and Technology, Dec 2021, Osaka, Japan. ⟨10.1145/3489849.3489888⟩. ⟨hal-03368978⟩
Collections
CNRS INRIA INRIA2
47 Consultations
95 Téléchargements
