Investigating hypotheses of neurodegeneration by learning dynamical systems of protein propagation in the brain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue NeuroImage Année : 2021
We introduce a theoretical framework for estimating, comparing and interpreting mechanistic hypotheses on long term protein propagation across brain networks in neurodegenerative disorders (ND). The model is expressed within a Bayesian non-parametric regression setting, where mechanisms of protein dynamics are inferred by means of gradient matching on dynamical systems (DS). The Bayesian formalism, combined with stochastic variational inference, naturally allows for model comparison via assessment of model evidence, while providing uncertainty quantification of causal relationship underlying protein progressions. When applied to in–vivo AV45-PET brain imaging data measuring topographic amyloid deposition in Alzheimer’s disease (AD), our model identified the mechanisms of accumulation, clearance and propagation as the best suited DS for bio-mechanical description of amyloid dynamics in AD, enabling realistic and accurate personalized simulation of amyloidosis.
S1053811921002573.pdf (7.26 Mo) Télécharger le fichier
hal-03374531 , version 1 (24-04-2023)
Paternité - Pas d'utilisation commerciale
Sara Garbarino, Marco Lorenzi. Investigating hypotheses of neurodegeneration by learning dynamical systems of protein propagation in the brain. NeuroImage, 2021, 235, pp.117980. ⟨10.1016/j.neuroimage.2021.117980⟩. ⟨hal-03374531⟩
30 Consultations
27 Téléchargements
