New interface
Journal articles
Improving statistical power of glaucoma clinical trials using an ensemble of cyclical generative adversarial networks
Abstract : Albeit spectral-domain OCT (SDOCT) is now in clinical use for glaucoma management, published clinical trials relied on time-domain OCT (TDOCT) which is characterized by low signal-to-noise ratio, leading to low statistical power. For this reason, such trials require large numbers of patients observed over long intervals and become more costly. We propose a probabilistic ensemble model and a cycle-consistent perceptual loss for improving the statistical power of trials utilizing TDOCT. TDOCT are converted to synthesized SDOCT and segmented via Bayesian fusion of an ensemble of GANs. The final retinal nerve fibre layer segmentation is obtained automatically on an averaged synthesized image using label fusion. We benchmark different networks using i) GAN, ii) Wasserstein GAN (WGAN) (iii) GAN + perceptual loss and iv) WGAN + perceptual loss. For training and validation, an independent dataset is used, while testing is performed on the UK Glaucoma Treatment Study (UKGTS), i.e. a TDOCT-based trial. We quantify the statistical power of the measurements obtained with our method, as compared with those derived from the original TDOCT. The results provide new insights into the UKGTS, showing a significantly better separation between treatment arms, while improving the statistical power of TDOCT on par with visual field measurements.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-03374539
Contributor : Project-Team Asclepios Connect in order to contact the contributor
Submitted on : Tuesday, October 12, 2021 - 10:56:46 AM
Last modification on : Friday, July 8, 2022 - 10:04:40 AM
Links full text
Identifiers
Citation
Georgios Lazaridis, Marco Lorenzi, Sebastien Ourselin, David Garway-Heath. Improving statistical power of glaucoma clinical trials using an ensemble of cyclical generative adversarial networks. Medical Image Analysis, 2021, 68, pp.101906. ⟨10.1016/j.media.2020.101906⟩. ⟨hal-03374539⟩
Share
Metrics
Record views
54
