Infinite-Dimensional Sums-of-Squares for Optimal Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce an approximation method to solve an optimal control problem via the Lagrange dual of its weak formulation. It is based on a sum-of-squares representation of the Hamiltonian, and extends a previous method from polynomial optimization to the generic case of smooth problems. Such a representation is infinite-dimensional and relies on a particular space of functions-a reproducing kernel Hilbert space-chosen to fit the structure of the control problem. After subsampling, it leads to a practical method that amounts to solving a semi-definite program. We illustrate our approach by a numerical application on a simple low-dimensional control problem.
Infinite_dim_sos_for_oc.pdf (1.77 Mo) Télécharger le fichier
hal-03377120 , version 1 (14-10-2021)
Eloïse Berthier, Justin Carpentier, Alessandro Rudi, Francis Bach. Infinite-Dimensional Sums-of-Squares for Optimal Control. 61st IEEE Conference on Decision and Control, IEEE, Dec 2022, Cancun, Mexico. ⟨hal-03377120⟩
235 Consultations
236 Téléchargements
