Evaluating Robustness over High Level Driving Instruction for Autonomous Driving - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In recent years, we have witnessed increasingly high performance in the field of autonomous end-toend driving. In particular, more and more research is being done on driving in urban environments, where the car has to follow high level commands to navigate. However, few evaluations are made on the ability of these agents to react in an unexpected situation. Specifically, no evaluations are conducted on the robustness of driving agents in the event of a bad high-level command. We propose here an evaluation method, namely a benchmark that allows to assess the robustness of an agent, and to appreciate its understanding of the environment through its ability to keep a safe behavior, regardless of the instruction.
Evaluating_Robustness_over_High_Level_Driving_Instruction_for_Autonomous_Driving.pdf (1.31 Mo) Télécharger le fichier
hal-03377799 , version 1 (14-10-2021)
  • HAL Id : hal-03377799 , version 1
Florence Carton, David Filliat, Jaonary Rabarisoa, Quoc Cuong Pham. Evaluating Robustness over High Level Driving Instruction for Autonomous Driving. IV 2021 - 32nd IEEE Intelligent Vehicles Symposium, Jul 2021, Nagoya, Japan. ⟨hal-03377799⟩
105 Consultations
97 Téléchargements
