Scar-Related Ventricular Arrhythmia Prediction from Imaging Using Explainable Deep Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The aim of this study is to create an automatic frameworkfor sustained ventricular arrhythmia (VA) prediction using cardiac com-puted tomography (CT) images. We built an image processing pipelineand a deep learning network to explore the relation between post-infarctleft ventricular myocardium thickness and previous occurrence of VA.Our pipeline generated a 2D myocardium thickness map (TM) from the3D imaging input. Our network consisted of a conditional variationalautoencoder (CVAE) and a classifier model. The CVAE was used tocompress the TM into a low dimensional latent space, then the classifierutilised the latent variables to predict between healthy and VA patient.We studied the network on a large clinical database of 504 healthy and182 VA patients. Using our method, we achieved a mean classificationaccuracy of 75%±4 on the testing dataset, compared to 71%±4 from theclassification using the classical left ventricular ejection fraction (LVEF).
scar_related_va_pred__fimh2021_buntheng (1).pdf (2.45 Mo) Télécharger le fichier
hal-03378951 , version 1 (15-10-2021)
Paternité
Buntheng Ly, Sonny Finsterbach, Marta Nuñez-Garcia, Hubert Cochet, Maxime Sermesant. Scar-Related Ventricular Arrhythmia Prediction from Imaging Using Explainable Deep Learning. FIMH 2021 - 11th International Conference on Functional Imaging and Modeling of the Heart, Jun 2021, Stanford, United States. pp.461-470, ⟨10.1007/978-3-030-78710-3_44⟩. ⟨hal-03378951⟩
60 Consultations
163 Téléchargements
