Symbolic Weighted Language Models, Quantitative Parsing and Verification over Infinite Alphabets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We study properties and relationship between three classes of quantitative language models computing over infinite input alphabets: Symbolic Weighted Automata (swA) at the joint between Symbolic Automata (sA) and Weighted Automata (wA), as well as Transducers (swT) and Visibly Pushdown (sw-VPA) variants. Like sA, swA deal with large or infinite input alphabets, and like wA, they output a weight value in a semiring domain. The transitions of swA are labeled by functions from an infinite alphabet into the weight domain. This generalizes sA, whose transitions are guarded by Boolean predicates overs symbols in an infinite alphabet, and also wA, whose transitions are labeled by constant weight values, and which deal only with finite alphabets. We present a Bar-Hillel Perles Shamir construction of a swA computing a swT-defined distance between a swA input language and a word, some closure results and a polynomial best-search algorithm for sw-VPA. These results are applied to solve a variant of parsing over infinite alphabets.
SW-parsing.pdf (518.91 Ko) Télécharger le fichier
hal-03380268 , version 1 (15-10-2021)
  • HAL Id : hal-03380268 , version 1
Florent Jacquemard, Philippe Rigaux, Lydia Rodriguez de La Nava. Symbolic Weighted Language Models, Quantitative Parsing and Verification over Infinite Alphabets. 2021. ⟨hal-03380268⟩
68 Consultations
104 Téléchargements
