New interface
Conference papers
Bifurcated Signatures: Folding the Accountability vs. Anonymity Dilemma into a Single Private Signing Scheme
Abstract : Over the development of modern cryptography, often, alternative cryptographic schemes are developed to achieve goals that in some important respect are orthogonal. Thus, we have to choose either a scheme which achieves the first goal and not the second, or vice versa. This results in two types of schemes that compete with each other. In the basic area of user privacy, specifically in anonymous (multi-use credentials) signing, such an orthogonality exists between anonymity and accountability. The conceptual contribution of this work is to reverse the above orthogonality by design, which essentially typifies the last 25 years or so, and to suggest an alternative methodology where the opposed properties are carefully folded into a single scheme. The schemes will support both opposing properties simultaneously in a bifurcated fashion, where: First, based on rich semantics expressed over the message’s context and content, the user, etc., the relevant property is applied point-wise per message operation depending on a predicate; and Secondly, at the same time, the schemes provide what we call “branch-hiding;” namely, the resulting calculated value hides from outsiders which property has actually been locally applied. Specifically, we precisely define and give the first construction and security proof of a “Bifurcated Anonymous Signature” (BiAS): A scheme which supports either absolute anonymity or anonymity with accountability, based on a specific contextual predicate, while being branch-hiding. This novel signing scheme has numerous applications not easily implementable or not considered before, especially because: (i) the conditional traceability does not rely on a trusted authority as it is (non-interactively) encapsulated into signatures; and (ii) signers know the predicate value and can make a conscious choice at each signing time. Technically, we realize BiAS from homomorphic commitments for a general family of predicates that can be represented by bounded-depth circuits. Our construction is generic and can be instantiated in the standard model from lattices and, more efficiently, from bilinear maps. In particular, the signature length is independent of the circuit size when we use commitments with suitable efficiency properties.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03380687
Contributor : Benoit Libert Connect in order to contact the contributor
Submitted on : Friday, October 15, 2021 - 5:04:27 PM
Last modification on : Friday, November 18, 2022 - 9:26:22 AM
Long-term archiving on: : Sunday, January 16, 2022 - 9:15:23 PM
File
CTSig.pdf
Identifiers
Collections
Citation
Benoît Libert, Khoa Nguyen, Thomas Peters, Moti Yung. Bifurcated Signatures: Folding the Accountability vs. Anonymity Dilemma into a Single Private Signing Scheme. Eurocrypt 2021 - 40th Annual International Conference on the Theory and Applications of Cryptographic Techniques, Oct 2021, Zagreb (partiellement virtuel), Croatia. pp.1-48, ⟨10.1007/978-3-030-77883-5_18⟩. ⟨hal-03380687⟩
Share
Metrics
Record views
39
Files downloads
209
