Education for the Multifaith Community of Cybersecurity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Steven Furnell
  • Fonction : Auteur
  • PersonId : 1108209
Matt Bishop
  • Fonction : Auteur
  • PersonId : 983834
The demand for cybersecurity professionals is growing. Many cybersecurity academic and training programmes exist to prepare students and professionals for these jobs. The programmes cover many areas of cybersecurity with considerable overlap, but with different emphases. Some are highly technical and cover little non-technical; others do the opposite. Cybersecurity jobs typically require some technical knowledge, an ability to place security problems in a larger context, and an ability to communicate this information effectively and convincingly. The problem with treating technical and non-technical subjects as silos rather than recognizing the two are tightly related and need to be taught together. This paper shows how seven common cybersecurity frameworks and ten masters’ courses from the UK and US cover both technical and non-technical content. It examines the balance of technical courses, non-technical courses, and courses that mix both technical and non-technical material. It argues that these topics cannot be siloed, and their balance is critical to meeting the goals of the frameworks and programmes.
497436_1_En_3_Chapter.pdf (2.64 Mo) Télécharger le fichier
hal-03380690 , version 1 (15-10-2021)
Paternité
Steven Furnell, Matt Bishop. Education for the Multifaith Community of Cybersecurity. 13th IFIP World Conference on Information Security Education (WISE), Sep 2020, Maribor, Slovenia. pp.32-45, ⟨10.1007/978-3-030-59291-2_3⟩. ⟨hal-03380690⟩
31 Consultations
27 Téléchargements
