A tangent linear approximation of the ignition delay time. II: Sensitivity to thermochemical parameters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Combustion and Flame Année : 2021
Mireille Hantouche
Saja Almohammadi
  • Fonction : Auteur
Omar M Knio
  • Fonction : Auteur
  • PersonId : 1095068
The tangent linear approximation (TLA) developed in Almohammadi et al. (Combust. Flame 230, 111426) is extended to estimate the sensitivity of the ignition delay time with respect to species enthalpies and entropies. The proposed method relies on integrating the linearized system of equations governing the evolution of the state vector's partial derivatives with respect to variations in thermodynamic parameters. The sensitivity of the ignition delay time is estimated through a linearized approximation of a temperature functional. The TLA approach is applied to three gas mixtures, H 2 , n-butanol, and iso-octane, reacting in air under adiabatic, constant-volume conditions. The numerical experiments indicate that the linearized approximation of the ignition delay time's sensitivity is in excellent agreement with the finite-difference estimates. This is also the case for sensitivity estimates obtained using the TLA approach. Further, significant computational speed-ups are achieved with the TLA approach, and the method scales well with the number of perturbed parameters. In the case of the H 2 mechanism, TLA is about ten times faster than finite differences, and this enhancement becomes even more substantial when more complex mechanisms are considered.
paper.pdf (787.76 Ko) Télécharger le fichier
hal-03384214 , version 1 (18-10-2021)
Mireille Hantouche, Saja Almohammadi, Olivier Le Maitre, Omar M Knio. A tangent linear approximation of the ignition delay time. II: Sensitivity to thermochemical parameters. Combustion and Flame, 2021, pp.111677. ⟨10.1016/j.combustflame.2021.111677⟩. ⟨hal-03384214⟩
30 Consultations
43 Téléchargements
