New interface
Conference papers
Modeling and Analyzing Resource-Sensitive Actors: A Tutorial Introduction
Abstract : Actor languages decouple communication from synchronization, which makes them suitable for distributed and scalable applications with flexible synchronization patterns, but also facilitates analysis. ABS is a timed actor-based modeling language which supports cooperative scheduling and the specification of timing- and resource-sensitive behavior. Cooperative scheduling allows a process which is executing in an actor to be suspended while it is waiting for an event to occur, such that another process in the same actor can execute. Timed semantics allows the specification of the temporal behavior of the modeled system. Resource-sensitive behavior takes a supply and demand perspective of execution, relating cost centers which provision resources to processes which require them. These modeling concepts have been used in ABS to model cloud computing, e.g., data-processing applications running on the Hadoop platform and micro-services running on containers orchestrated by Kubernetes. In this tutorial, we present ABS and its execution environment, and discuss the use of cooperative scheduling and resources in modeling cyber-physical systems and applications deployed on virtualized infrastructure.
Complete list of metadata
https://hal.inria.fr/hal-03387836
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, October 20, 2021 - 9:00:37 AM
Last modification on : Wednesday, October 20, 2021 - 10:24:28 AM
Long-term archiving on: : Friday, January 21, 2022 - 7:18:12 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2024-01-01
Please log in to resquest access to the document
Identifiers
Citation
Rudolf Schlatte, Einar Broch Johnsen, Eduard Kamburjan, Silvia Lizeth Tapia Tarifa. Modeling and Analyzing Resource-Sensitive Actors: A Tutorial Introduction. 23th International Conference on Coordination Languages and Models (COORDINATION), Jun 2021, Valletta, Malta. pp.3-19, ⟨10.1007/978-3-030-78142-2_1⟩. ⟨hal-03387836⟩
Share
Metrics
Record views
15
