How Machine Learning changes the nature of cyberattacks on IoT networks: A survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications Surveys and Tutorials, IEEE Communications Society Année : 2021
The Internet of Things (IoT) has continued gaining in popularity and importance in everyday life in recent years. However, this development does not only present advantages. Indeed, due to the number of sensitive and private data produced by IoT systems, they have become the new privileged targets for cyberattackers. At the same time, Machine Learning (ML) has gained a phenomenal success in various fields like telecommunications, transport or cybersecurity. Nonetheless, the application of ML can cause significant damage when put in the hands of an attacker. Contrary to many previous works, we do not focus on the potential contributions of ML in the IoT security systems. Indeed, this survey aims to provide a comprehensive overview of ML approaches to enable more effective and less detectable attacks. Thereby, the purpose of this article is to identify and discuss the advantages of the elaboration of ML attacks and the possible solutions already evoked in the literature. Firstly, we provide an identification of the main threats and potential attacks on IoT networks. Then, we investigate on cyberattacks integrating machine learning algorithms during the last few years and we provide future research directions, especially for jamming, side channel, false data injection and adversarial machine learning attacks.
How-machine-learning-change.pdf (515.85 Ko) Télécharger le fichier
hal-03390359 , version 1 (21-10-2021)
Emilie Bout, Valeria Loscri, Antoine Gallais. How Machine Learning changes the nature of cyberattacks on IoT networks: A survey. Communications Surveys and Tutorials, IEEE Communications Society, 2021, 24 (1), pp.248-279. ⟨10.1109/COMST.2021.3127267⟩. ⟨hal-03390359⟩
166 Consultations
1074 Téléchargements
