Extracting Hyperparameter Constraints from Code - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Machine-learning operators often have correctness constraints that cut across multiple hyperparameters and/or data. Violating these constraints causes runtime exceptions, but they are usually documented only informally or not at all. This paper presents a weakest precondition analysis for Python code. We demonstrate our analysis by extracting hyperparameter constraints for 45 sklearn operators. Our analysis is a step towards safer and more robust machine learning.
ssmls_iclr21.pdf (148.8 Ko) Télécharger le fichier
hal-03401683 , version 1 (25-10-2021)
  • HAL Id : hal-03401683 , version 1
Ingkarat Rak-Amnouykit, Ana Milanova, Guillaume Baudart, Martin Hirzel, Julian Dolby. Extracting Hyperparameter Constraints from Code. ICLR Workshop on Security and Safety in Machine Learning Systems, May 2021, Virtual, United States. ⟨hal-03401683⟩
79 Consultations
256 Téléchargements
