Compiling Stan to generative probabilistic languages and extension to deep probabilistic programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stan is a probabilistic programming language that is popular in the statistics community, with a high-level syntax for expressing probabilistic models. Stan differs by nature from generative probabilistic programming languages like Church, Anglican, or Pyro. This paper presents a comprehensive compilation scheme to compile any Stan model to a generative language and proves its correctness. We use our compilation scheme to build two new backends for the Stanc3 compiler targeting Pyro and NumPyro. Experimental results show that the NumPyro backend yields a 2.3x speedup compared to Stan in geometric mean over 26 benchmarks. Building on Pyro we extend Stan with support for explicit variational inference guides and deep probabilistic models. That way, users familiar with Stan get access to new features without having to learn a fundamentally new language.
pldi21.pdf (2.4 Mo) Télécharger le fichier
hal-03401742 , version 1 (25-10-2021)
Guillaume Baudart, Javier Burroni, Martin Hirzel, Louis Mandel, Avraham Shinnar. Compiling Stan to generative probabilistic languages and extension to deep probabilistic programming. PLDI '21 - 42nd ACM SIGPLAN International Conference on Programming Language Design and Implementation, Jun 2021, Virtual, Canada. pp.497-510, ⟨10.1145/3453483.3454058⟩. ⟨hal-03401742⟩
38 Consultations
113 Téléchargements
