Semi-supervised Consensus Clustering Based on Closed Patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Knowledge-Based Systems Année : 2022
Semi-supervised consensus clustering, also called semi-supervised ensemble clustering, is a recently emerged technique that integrates prior knowledge into consensus clustering in order to improve the quality of the clustering result. In this article, we propose a novel semi-supervised consensus clustering algorithm extending the previous work on the MultiCons multiple consensus clustering approach. By using closed pattern mining technique, the proposed Semi-MultiCons algorithm manages to generate a recommended consensus solution with a relevant inferred number of clusters k based on ensemble members with different k and pairwise constraints. Compared with other semi-supervised and/or consensus clustering approaches, Semi-MultiCons does not require the number of generated clusters k as an input parameter, and is able to alleviate the widely reported negative effect related to the integration of constraints into clustering. The experimental results demonstrate that the proposed method outperforms state of the art semi-supervised consensus clustering algorithms.
S0950705121008613.pdf (1.91 Mo) Télécharger le fichier
hal-03402517 , version 1 (05-01-2024)
Paternité - Pas d'utilisation commerciale
Tianshu Yang, Nicolas Pasquier, Frédéric Precioso. Semi-supervised Consensus Clustering Based on Closed Patterns. Knowledge-Based Systems, 2022, Article 107599, 235, ⟨10.1016/j.knosys.2021.107599⟩. ⟨hal-03402517⟩
145 Consultations
14 Téléchargements
