A PPM-like, tag-based branch predictor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Journal of Instruction-Level Parallelism Année : 2005
Pierre Michaud
  • Fonction : Auteur
  • PersonId : 738135
  • IdHAL : pmichaud
This paper describes cbp1.5, the tag-based, global-history predictor derived from PPM that was rank five at the first Championship Branch Prediction competition. This predictor is a particular instance of a family of predictors which we call GPPM. We introduce GPPMideal, an ideal GPPM predictor. It is possible to derive cbp1.5 from GPPM-ideal by introducing a series of degradations corresponding to real-life constraints. We characterize cbp1.5 by quantifying the impact of each degradation on the distributed CBP traces.
jilp.pdf (122.86 Ko) Télécharger le fichier
hal-03406188 , version 1 (29-10-2021)
  • HAL Id : hal-03406188 , version 1
Pierre Michaud. A PPM-like, tag-based branch predictor. The Journal of Instruction-Level Parallelism, 2005, 7, pp.10. ⟨hal-03406188⟩
160 Consultations
412 Téléchargements
