A Bayesian tracker for synthesizing mobile robot behaviour from demonstration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Autonomous Robots Année : 2021
Programming robots often involves expert knowledge in both the robot itself and the task to execute. An alternative to direct programming is for a human to show examples of the task execution and have the robot perform the task based on these examples, in a scheme known as learning or programming from demonstration. We propose and study a generic and simple learning-from-demonstration framework. Our approach is to combine the demonstrated commands according to the similarity between the demonstrated sensory trajectories and the current replay trajectory. This tracking is solely performed based on sensor values and time and completely dispenses with the usually expensive step of precomputing an internal model of the task. We analyse the behaviour of the proposed model in several simulated conditions and test it on two different robotic platforms. We show that it can reproduce different capabilities with a limited number of meta parameters.
bayesian-replay.pdf (1.39 Mo) Télécharger le fichier
hal-03408925 , version 1 (29-10-2021)
hal-03408925 , version 2 (02-11-2021)
Stéphane Magnenat, Francis Colas. A Bayesian tracker for synthesizing mobile robot behaviour from demonstration. Autonomous Robots, 2021, ⟨10.1007/s10514-021-10019-4⟩. ⟨hal-03408925v2⟩
143 Consultations
122 Téléchargements
