Definition of the fluctuation function in the detrendred fluctuation analysis and its variant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The European Physical Journal B: Condensed Matter and Complex Systems Année : 2021
The detrended fluctuation analysis (DFA) and its variants are popular methods to analyze the self-similarity of a signal. Two steps characterize them: firstly, the trend of the centered integrated signal is estimated and removed. Secondly, the properties of the so-called fluctuation function which is an approximation of the standard deviation of the resulting process is analyzed. However, it appears that the statistical mean was assumed to be equal to zero to obtain it. As there is no guarantee that this assumption is true a priori, this hypothesis is debatable. The purpose of this paper is to propose two alternative definitions of the fluctuation function. Then, we compare all of them based on a matrix formulation and the filter-based interpretation we recently proposed. This analysis will be useful to show that the approach proposed in the original paper remains a good compromise in terms of accuracy and computational cost.
Fichier non déposé
hal-03409799 , version 1 (30-10-2021)
Bastien Berthelot, Eric Grivel, Pierrick Legrand, Audrey Giremus. Definition of the fluctuation function in the detrendred fluctuation analysis and its variant. The European Physical Journal B: Condensed Matter and Complex Systems, 2021, 94, ⟨10.1140/epjb/s10051-021-00231-7⟩. ⟨hal-03409799⟩
82 Consultations
0 Téléchargements
