Function Space Pooling for Graph Convolutional Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Convolutional layers in graph neural networks are a fundamental type of layer which output a representation or embedding of each graph vertex. The representation typically encodes information about the vertex in question and its neighbourhood. If one wishes to perform a graph centric task, such as graph classification, this set of vertex representations must be integrated or pooled to form a graph representation. In this article we propose a novel pooling method which maps a set of vertex representations to a function space representation. This method is distinct from existing pooling methods which perform a mapping to either a vector or sequence space. Experimental graph classification results demonstrate that the proposed method generally outperforms most baseline pooling methods and in some cases achieves best performance.
497121_1_En_26_Chapter.pdf (1.08 Mo) Télécharger le fichier
hal-03414745 , version 1 (04-11-2021)
Paternité
Padraig Corcoran. Function Space Pooling for Graph Convolutional Networks. 4th International Cross-Domain Conference for Machine Learning and Knowledge Extraction (CD-MAKE), Aug 2020, Dublin, Ireland. pp.473-483, ⟨10.1007/978-3-030-57321-8_26⟩. ⟨hal-03414745⟩
38 Consultations
2 Téléchargements
