Accuracy Assessment of Li-ion Batteries Internal Resistance Model Through CFD Simulations, Experimental Measurements And Uncertainties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Internal resistance is a critical parameter of the thermal behavior of Li-ion battery cells. This paper proposes an innovative way to deal with the uncertainties related to this physical parameter using experimental data and numerical simulation. First, a CFD model is validated against an experimental configuration representing the behavior of heated Li-ion battery cells under constant discharging current conditions. Secondly, an Uncertainty Quantification based methodology is proposed to represent the internal resistance and its inherent uncertainties. Thanks to an accurate and fast to compute surrogate model, the impact of those uncertainties on the temperature evolution of Li-ion cells is quantified. Finally, a Bayesian inference of the internal resistance model parameters using experimental measurements is performed, permitting to reduce the prediction uncertainty by almost 95% for some temperatures of interest.
ProceedingsHEFAT_solai.pdf (1.32 Mo) Télécharger le fichier
hal-03417087 , version 1 (05-11-2021)
  • HAL Id : hal-03417087 , version 1
Elie Solai, Héloïse Beaugendre, Ulrich Bieder, Pietro Marco Congedo. Accuracy Assessment of Li-ion Batteries Internal Resistance Model Through CFD Simulations, Experimental Measurements And Uncertainties. HEFAT 2021 - 15th International Conference on Heat Transfer, Fluid Mechanics and Thermodynamics, Jul 2021, Virtual conference, Netherlands. ⟨hal-03417087⟩
109 Consultations
113 Téléchargements
