Parallel Complexity of Term Rewriting Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this workshop paper, we revisit the notion of parallel-innermost term rewriting. We provide a definition of parallel complexity and propose techniques to derive upper bounds on this complexity via the Dependency Tuple framework by Noschinski et al.
wst2021.pdf (407.96 Ko) Télécharger le fichier
hal-03418400 , version 1 (07-11-2021)
  • HAL Id : hal-03418400 , version 1
Thaïs Baudon, Carsten Fuhs, Laure Gonnord. Parallel Complexity of Term Rewriting Systems. WST 2021 - 17th International Workshop on Termination, Jul 2021, Virtual, France. pp.1-6. ⟨hal-03418400⟩
75 Consultations
83 Téléchargements
