New interface
Journal articles
Comparison of high-order Eulerian methods for electron hybrid model
Anaïs Crestetto 1 Nicolas Crouseilles 2, 3 Yingzhe Li 4 Josselin Massot 2, 3
3 MINGUS - Multi-scale numerical geometric schemes
IRMAR - Institut de Recherche Mathématique de Rennes, ENS Rennes - École normale supérieure - Rennes, Inria Rennes – Bretagne Atlantique
Abstract : In this work, we focus on the numerical approximation of a hybrid fluid-kinetic plasma model for electrons, in which energetic electrons are described by a Vlasov kinetic model whereas a fluid model is used for the cold population of electrons. First, we study the validity of this hybrid modelling in a two dimensional context (one dimension in space and one dimension in velocity) against the full (stiff) Vlasov kinetic model and second, a four dimensional configuration is considered (one dimension in space and three dimensions in velocity) following [1]. To do so, we consider two numerical Eulerian methods. The first one is based on the Hamiltonian structure of the hybrid system and the second approach, which is based on exponential integrators, enables to derive high order integrator and remove the CFL condition induced by the linear part. The efficiency of these methods, which are combined with an adaptive time stepping strategy, are discussed in the different configurations and in the linear and nonlinear regimes.
Complete list of metadata
https://hal.inria.fr/hal-03418778
Contributor : Nicolas Crouseilles Connect in order to contact the contributor
Submitted on : Monday, November 8, 2021 - 10:05:06 AM
Last modification on : Friday, May 20, 2022 - 9:04:53 AM
Long-term archiving on: : Wednesday, February 9, 2022 - 7:46:08 PM
File
vmhl_1d_3v_submit.pdf
Identifiers
Citation
Anaïs Crestetto, Nicolas Crouseilles, Yingzhe Li, Josselin Massot. Comparison of high-order Eulerian methods for electron hybrid model. Journal of Computational Physics, 2022, 451 (article n° 110857), ⟨10.1016/j.jcp.2021.110857⟩. ⟨hal-03418778⟩
Share
Metrics
Record views
67
Files downloads
127
