A Reduction Algorithm for Matrices Depending on a Parameter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
In this article, we study square matrices perturbed by a parameter $\epsilon$. An efficient algorithm computing the $\epsilon$-expansion of the eigenvalues in formal Laurent-Puiseux series is provided, for which the computation of the characteristic polynomial is not required. We show how to reduce the initial matrix so that the Lidskii-Edelman-Ma perturbation theory can be applied. We also explain why this approach may simplify the perturbed eigenvector problem. The implementation of the algorithm in the computer algebra system Maple has been used in a quantum mechanics context to diagonalize some perturbed matrices and is available.
JeaPfl1999.pdf (212.93 Ko) Télécharger le fichier
hal-03419442 , version 1 (08-11-2021)
  • HAL Id : hal-03419442 , version 1
Claude-Pierre Jeannerod, Eckhard Pflügel. A Reduction Algorithm for Matrices Depending on a Parameter. International Symposium on Symbolic and Algebraic Computation (ISSAC), Jul 1999, Vancouver, Canada. ⟨hal-03419442⟩
Collections
UGA CNRS LMC-IMAG
30 Consultations
110 Téléchargements
