Input-to-state stability of time-delay Persidskii systems
We consider in this work a class of generalized Persidskii systems with time delays. The input-to-state stability and stabilization conditions for these nonlinear systems are introduced and checked through linear matrix inequalities. A numerical example demonstrates the efficacy of the proposed results.
Automatique / Robotique
